ASAP Help With IAC!
Old Apr 4, 2011 | 11:28 AM
CyrilKeir's Avatar
CyrilKeir
Default ASAP Help With IAC!
I am in the middle of swapping out my old Idle Air Controller with a new one, to fix some issues I was having. But after putting the new one in, I fired up the car.
It revved pretty high, then when it went into idle mode, it kept going chugga chugga. Rev-stop-rev-stop-rev-stop.
I pulled it BACK out, and compared it to the old one. I bought the new IAC at Advanced Autoparts....
New one is on the left. Notice the difference in length?
So my question is... WHAT do I do now? This was the IAC they said was for the 2000 dodge neon. They even had to order it.
Old Apr 4, 2011 | 11:37 AM
CyrilKeir's Avatar
CyrilKeir
Ok I just pushed on the top of the old one, and now they are the same length... apparently it was extended or something.
So is it normal after putting in a new IAC for the car to act really weird? Will it adjust to the new valve?
Old Apr 4, 2011 | 12:58 PM
buddhaman's Avatar
buddhaman
disconnect the battery for a little bit then hook it back up.
Old Apr 4, 2011 | 01:37 PM
CyrilKeir's Avatar
CyrilKeir
Ok, someone can delete this thread.
After running it for a bit ( I ran errands) everything is working fine.
Old Apr 4, 2011 | 11:01 PM
Moparkyle's Avatar
Moparkyle
Yeah it just had to relearn where it was.
