2000 neon hard starting
Old Apr 10, 2011 | 10:50 PM
cubstowin's Avatar
cubstowin
Default 2000 neon hard starting
Hi I have a 2000 neon The fuel pressure is fine when car is running but drops off when you turn the car off. Is it suppose to maintain pressure or is this normal. I have been wondering if that could be why the car cranks a long time before starting.
Old Apr 11, 2011 | 05:50 PM
hemi4spd's Avatar
hemi4spd
pressure should remain long after you shut the car off, this is not normal operation
Your Issue is:
fuel pressure regulator has gone for a poop
its located on the tank and includes new pump/and float and reg all in one, which is a shamecuz u have to replace things that are still good(ie pump/float) but I pretty sure its a whole unit design and you cant rebuild the reg
It's likely to set u back about 150 doing it urself (i suggest when the car has a near empty tank). This is also a great time to do a fuel filter(hint hint)
the only special tool you may need is a large spanner to remove the fuel sending unit locknut. a strap wrench works well on this too
Old Apr 12, 2011 | 11:37 PM
Moparkyle's Avatar
Moparkyle
It's supposed to hold a decent amount of pressure for a pretty long time.
That is why you can leave your car overnight and it will still start speedily.
Old Jul 2, 2013 | 01:49 PM
iowaman0322's Avatar
iowaman0322
i have a 2000 plymouth neon which i assume is the same as a dodge. i have the same problem haven't had the pressure checked though. The only other problem i have along with it is if i turn the key to crank position but don't start. Then, back off then go to start it. it will start easier but like it should.
