air sucking sound
Old Apr 15, 2011 | 07:16 PM
wargod4200's Avatar
wargod4200
Default air sucking sound
hello i have my 02 neon 116425 miles and today i was driving to the store and when i went to take off from a stop light my car make a huge air sucking sound like i have a short ram intake or something but im stock and when im driving if i push the pedal down not real hard it will make that sound but if i slightly slip the cluch or push it all the way down the sound will stop and it will not make that sound in nutreal i can rev it up and no sucking sound what could that be and where to look
ps no cel light
Old Apr 15, 2011 | 11:29 PM
wargod4200's Avatar
wargod4200
Default update
ok i went out and was checking for cracks in the hoses and found nothing so i took wd40 cause i had no tb cleaner to spray so i sprayed the manifold to see if the idle change and nothing so i sprayed the injectors and nothing so i took off the tb air tube to look for cracks and i took a paper towel and wiped the inside of the intake man and sure enough the paper towel was coveved in wd40 so either the intake or the injectors is leaking
Old Apr 15, 2011 | 11:33 PM
wargod4200's Avatar
wargod4200
damm i forgot to ask i got felpro intake gaskets and do you and type of sealer or just bolt them down
Old Apr 16, 2011 | 10:20 PM
hemi4spd's Avatar
hemi4spd
bolt em on dry to appropriate torque specs
