bellow tube
Old May 4, 2011 | 07:18 PM
buddhaman's Avatar
buddhaman
Default bellow tube
i was thinking about the tube between the TB and intake manifold and it looks like it would cause the air flowing through to be more turbulent so i decided to change it. i had some exhaust flex pipe laying around and some connectors so i made this Name:  Photo-0042.jpg
Size:  36.5 KB. after i put that on i hooked everything back up and it seems to fit well and look better.Name:  Photo-0043.jpg
i haven't taken it for a drive yet but i'll post later on how it drives and if i notice any pros/cons about it.
Old May 5, 2011 | 12:01 PM
buddhaman's Avatar
buddhaman
well took it for a drive and i think i made it too long.. time to bring out the dremel and see how it turns out
Old May 5, 2011 | 12:13 PM
krain88's Avatar
krain88
How did u get it to stay up and not bounce around without the mounting brackets?
Old May 5, 2011 | 12:15 PM
buddhaman's Avatar
buddhaman
it's a lot stiffer now but i'll make a bracket for it once i get everything set in place. plus the air filter is resting on the wheel well
Old May 7, 2011 | 12:43 PM
Moparkyle's Avatar
Moparkyle
That seems like it's a little small in diameter.
Old May 7, 2011 | 12:58 PM
buddhaman's Avatar
buddhaman
it's actually the same size as the inside of the stock tube
Old May 7, 2011 | 02:27 PM
darthroush's Avatar
darthroush
Section Moderator
It probably looks like a smaller I.D. because there aren't bellows sticking out that serve no purpose.
Old May 7, 2011 | 06:53 PM
Moparkyle's Avatar
Moparkyle
That could be it, I was like damn that thing is small.
Old May 7, 2011 | 10:10 PM
buddhaman's Avatar
buddhaman
yeah the ridges on the outside are almost an inch long so it looks a lot bigger than it is. in all reality it's the same size and the opening for the TB.
