Noob!!!
Old May 5, 2011 | 02:09 PM
srtdreamer23's Avatar
srtdreamer23
Unhappy Noob!!!
Hello,
the names dylon. I am the proud owner of a 2000 dodge neon ES.
I have loved the neon since it's first induction to the us car list.
Yes i was four, but that only means i grew up with them.(lol)
My problem is that when im driving, or sitting, sometimes my gauges will start bouncing up and down. Not like a little up n down bounce either.
They will completely shut off, then turn back on, then drop down a little then shut off, etc..
My question is, does this come from a bad PCM or is it my cluster?
Also my fuse light comes on and i've checked every fuse from hood to trunk and none of them are bad.
Help me save my baby!
Thnx!!
Old May 5, 2011 | 04:32 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site. I would pull out the instrument cluster and check the connections in the back first since all of them are acting up.
Old May 5, 2011 | 05:43 PM
seabass202's Avatar
seabass202
also check your charging system and BATTERY! these things are very picky when it comes to proper voltage.
Old May 5, 2011 | 07:39 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the second generation Neon section,
FF
Old May 5, 2011 | 08:56 PM
darthroush's Avatar
darthroush
Section Moderator
Agreed on checking the battery first.
Old May 5, 2011 | 10:01 PM
peelerboy's Avatar
peelerboy
When the battery was in the process of dying on my `03 SRT-4, it did the very same thing Dylon's car is doing. Replaced the battery and it never happened again.
Old May 5, 2011 | 11:09 PM
darthroush's Avatar
darthroush
Section Moderator
I've had a bad battery that caused more that weird gauge problems, and I've had battery wiring go bad and/or come loose a few other times that caused the gauge problems and then some as well.
Old May 9, 2011 | 12:22 PM
srtdreamer23
Default Thanks
Thanks. i did end up getting a new battery and it hasnt done it since. Now its just the fuse light that will come on now and again.
Old May 10, 2011 | 01:27 AM
darthroush's Avatar
darthroush
Section Moderator
Check the engine grounds.
