Radio and Ac fan and Lights and Odometer blanks out
I'll check it out thanks........and do you have to check under the connections in the box? Any pictures of where to look and how to do? Thanks again and I hope you fixed the rough idle situation you had going on. I did by backing the motor mount bolts from the wheel well just a bit it now idles smooth as silk.
doncha love problems that fix themselves??
its not uncommon to have lyme disease on the backside of the PDC, when u get a chance remove the bolts that hold it to the body and flip it over to inspect, since its all attached by wires it wont move much but enough to flip it over
Follow up to this story is that yeah it was the battery post it got worse and I finally as a last resort cleaned them and waalaa it went away. Thanks a lot for all the help. I'm sure this saved me a lot of money by doing it myself through the knowledge of this forum, I was able to fix this.
