2000 neon door will not open
Old May 19, 2011 | 04:40 PM
jercar's Avatar
jercar
Default 2000 neon door will not open
Left rear door is in closed position. The actuator was making a noise so I removed the inside door panel. I closed the door, now I can't get it to open from the inside or outside, locked or unlocked, soleniod wired or unwired. I think I tried all combinations. Is there any way to manually move the latch from inside the door? Pulling on the rods seem to have no effect.
Old Jan 4, 2026 | 03:06 PM
Aedan W's Avatar
Aedan W
I'm having a similar issue with the same door. The door panel is left on, doesn't open from either side (child lock is on). Did you get this fixed? If so, I hope you see this.
