2001 neon 2.0 sohc compression
Old May 25, 2011 | 11:20 AM
jake122288's Avatar
jake122288
Default 2001 neon 2.0 sohc compression
I bought a compression tester today, and i was wondering what is the correct procedure to check compression?
I am also curious what the normal compression range is?
Also on my lists of testing i bought a fuel pressure gauge, and was wondering the correct way to test that, as well as the normal (good range).
Thanks in advance
