Looking for help electrically, 2000 Neon
Old Jun 10, 2011 | 09:25 PM
dadibones's Avatar
dadibones
Same question for the cam and crank sensors...can they work just fine for awhile then just go **** up shutting everything down, then decide to go to working again?
Old Jun 10, 2011 | 11:46 PM
hemi4spd's Avatar
hemi4spd
yes Cam and crank sensors can fail when hot and work fine cold.
as for the asd failing under heat is possible but ez to rule out, just swap another relay in its place
given the info so far i'd be inclined to look into the cam sensors mag field breaking down due to heat (just my 2 cents)
Old Jun 17, 2011 | 06:38 PM
dadibones's Avatar
dadibones
Hemi... is the mag field part of the cam position sensor when ordered or is it a separate item? I don't see "mag field" listed in many of the internet parts houses.
Old Jun 18, 2011 | 04:54 AM
darthroush's Avatar
darthroush
Section Moderator
It is sold separately AFAIK. Look for "cam magnet."
Old Jun 18, 2011 | 02:36 PM
hemi4spd's Avatar
hemi4spd
by Mag Field i was referring to the Magnetic field(or force) created by the sensor.
electro magnets(cam/crank sensors) create a magnetic field and when a piece of steel or another magnet pass by it disrupts the magnetic field, telling the computer the required info. After time these sensors can break down due to heat or vibrations or just plain age, thus making erratic or inconsistent info for the computer.
the magnet/or steel trigger that is imbedded in the cam is a seperate piece, although not impossible to fall out, it is unlikely. (especially cuz u say car will work again when cools off, if the cam's indexing magnet/or steel button fell out it would NEVER refire.)
Im heading down the path of a failing sensor, verify integrity of the sensors wiring before replacement.
Old Jun 18, 2011 | 03:41 PM
dadibones's Avatar
dadibones
Thanx hemi...I've read alot on these forums, etc. that I should purchase mopar parts (I'm referencing the cam sensor now) because aftermarkets just don't cut it. Is this an absolute or can I get a non OE sensor and feel kinda confident with it? I get all my parts when ordered off internet from Rockauto and have been completely satisfied with their quality and service. This car is used with mucho mileage and don't want to sinks loads of money for parts into it.
Old Jun 20, 2011 | 09:29 AM
hemi4spd's Avatar
hemi4spd
I myself prefer OEM sensors but aftermarket ones do work.
believe it or not some aftermarket products are better than OEM (no grease fittings on stock joints)
buy what you can afford, an aftermarket sensor that works beats a dead OEM one anyday.
