Looking for help electrically, 2000 Neon
While traveling to work the other day my Neon died...electrically still active, the engine just died. Had car towed home, when unloaded it started right up. Drove again on a "practice" run and it ran fine for about a 15 minute drive. Parked car for shopping, went to start it up, starter cranks just great but no start. Sat in car for about 15 minutes (cussing I might add) and try to start again. Fired right up, halfway home it died again, started up after about a 10 minute cussing bout. cruised right on home without trouble. You know my question..."What would cause this?" I've read many of the forums here and I bet you'll suggest many sensors, electrical grounds, etc....Instead of just throwing parts at the car can the ckp, cmp, ignition module, wiring harnesses, etc. be tested before I just buy the part hoping it fixes the problem? Thanks for any help you can offer!!
I forgot to mention...no obd codes were locked in which gives me a needle in a haystack feeling here. Dart, could you be more specific... 'DMM'...????...'FSM'...??? (I'm new here so give me a break).
you may want to still have the car scanned for trouble codes as there could be pending codes. a great way to diagnose this car is have handy a spark tester and or fuel pressure tester when the car wont start so when it fails you can check for spark and fuel and really narrow your diagnosis down. spark testers can be had at any auto parts store and easily hook right in to a spark plug wire and clip to ground nad crank engine and observe. also hooking up and taping to your winshield a fuel pressure tester can yield alot of info especially while your driving and the car fails. this is a very basic starting point and allows you to follow a further diagnostic preocedure. if you have questions let me know , im a ASE certified tech by the way.
I had the ASD code coming up, so I took a gamble besides the research I did in my neon manuals and tried the camshaft sensor and it cleared my problem up which sounds very similar to yours. I figured 25 bucks was a safe gamble.
Trending Topics
Can the ASD relay intermittently go bad (possibly in an overheated environment) and then go to working again or are they designed for when they go bad they are done for and replacement is required? I've checked every wire I can get to in this thing and am still searching for that needle.
