2nd gen neon system install question
Old Jun 9, 2011 | 12:32 AM
xarkhun's Avatar
xarkhun
Default 2nd gen neon system install question
i'm atempting to install amp and subs in my 2003 neon sxt and cant find a good spot to run the amp power cable through the fire wall does anyone one know of a good place to run it or do i need to drill a hole?
Old Jun 9, 2011 | 07:59 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this to the second generation Neon section,
FF
Old Jun 9, 2011 | 12:49 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site
Any empty grommets? What about through the one with the speedo cable?
Old Jun 9, 2011 | 01:17 PM
darthroush's Avatar
darthroush
Section Moderator
Upper right corner of the firewall where the factory harness goes through.
Old Jun 9, 2011 | 03:26 PM
ealerp's Avatar
ealerp
what size wire are you running? I ran a 0 gauge through the steering column no problem. just pull the rubber seal back a bit and have someone inside to pull it through once you have it in far enough they can get a grip on it.
Old Jun 9, 2011 | 10:01 PM
xarkhun's Avatar
xarkhun
thanx for all the help i just saw the spot where the factory harness goes threw i thought about the steering colum boot but i didn't want to take the chance of it getting wrapped around the steering colum its a 4 gauge wire
