oil light
Old Jul 13, 2011 | 06:06 PM
04sled's Avatar
04sled
Default oil light
so today scarred me... I was in tampa and on my way home the oil light started flickering... I pulled over checked the oil it was fine, As I incresed the rpm's it went away but I was still nervous.. then the darn light comes on solid I figured I was in for a motor now 5 minutes went by then 45 minutes and I was home no engine tick or tap at all the temp guage never moved from it's normal place... So happy to say it has to be a bad sending unit or a bad wire...
Old Jul 13, 2011 | 09:54 PM
darthroush's Avatar
darthroush
Section Moderator
Mine has been coming on at random lately. I think I'm going to have to get ANOTHER one.
Old Jul 14, 2011 | 08:53 PM
04sled's Avatar
04sled
is this a common problem with the neon's?
Old Jul 14, 2011 | 10:17 PM
hemi4spd's Avatar
hemi4spd
lol dodge sending units have been pretty weak since the late 60's.
the old trick was to install a chevy sender as they required even lower pressure to activate the idiot light.
sometimes when your oil gets old and thinned out too much willl cause the light to flicker at low RPMs
the answer= install an oil pressure gauge and ignore the idiot light, at least then you'll have a actual value of what oil pressure you have.
Old Jul 15, 2011 | 05:09 AM
darthroush's Avatar
darthroush
Section Moderator
Dodge says oil pressure is 4PSI at curb idle. If the Chevy sender requires even less...
Old Jul 16, 2011 | 10:52 PM
hemi4spd's Avatar
hemi4spd
the old trick applies to the old senders
used to be rated
dodge= 15-18psi
chev= 11-13psi
this was long before the neon was ever dreamt of I doubt they can be swapped today. Just mereley illustrating sending units have been a joke for a while, thats why I never rely on idiot lights
Old Jul 17, 2011 | 04:26 AM
darthroush's Avatar
darthroush
Section Moderator
Most are anymore for reasons I'm sure you're aware of. That's why when my light comes on, I ignore it and restart the car. Light off.
Old Jul 17, 2011 | 11:03 AM
showsxt's Avatar
showsxt
CHange the oil sensor and see if that helps. Mine use to do that and changed the sensor and solved the problem.
Old Jul 17, 2011 | 03:27 PM
04sled's Avatar
04sled
anyone know if its the one with the green plug top on the left side of the exhaust manifold
Old Jul 17, 2011 | 03:59 PM
darthroush's Avatar
darthroush
Section Moderator
Should be. It's the only one in that area IIRC.
