Charging System Issue, Need Help
Old Jul 30, 2011 | 06:24 PM
The_Grimy_One's Avatar
The_Grimy_One
Default Charging System Issue, Need Help
Hey guys,
Well I was swapping out my alt for a PT alt to get some more amps for my audio system. Well I ran a larger wire to my batt and it ended up getting grounded out on the catalytic converter, which is totally my fault
I have tried 2 diff alts, and my electrical light is still on and my batt is not being charged...
I then got my stock alt, new alt, and batt tested, all are in working condition. So now I must trouble shoot this issue. Well I did some research and someone said that it could be the voltage regulator, and that it is in the PCM. Is this true? I have an 03 SE. Another guy said that I could pick up a 14V regulator from an auto parts store and run it between the alt and batt, (I have been having trouble finding any though).
Please let me know what you think... My car is pretty much unusable from my stupid mistake :/ I did find a PCM for like $160, but dont want to spend that if its not what I need. I have checked all the wiring, the best as I can, but cant see all of it. Also, could it be a relay or fuse? Checked all the fuses in the fuse box and dash area, I believe all are good.
Old Jul 30, 2011 | 06:42 PM
darthroush's Avatar
darthroush
Section Moderator
That is why a fuse should be added to any line coming directly to/from the battery, most especially when running a cable from the alternator.
The regulator inside of the PCM can't be bypassed AFAIK; and if the internal voltage regulator is damaged, the PCM must be replaced. If all fuses and relays are good, it sounds like a PCM might be needed.
Old Jul 30, 2011 | 06:45 PM
The_Grimy_One
Ok, and actually the wire wasnt connected to the battery yet, I had it tied to up, because I needed a nut to connect it to the terminal. I do have a fuse to run between it. Is it possible to check the relays? I will check all fuses again. I didnt see any that had to do with the alternator either...
Old Jul 30, 2011 | 06:46 PM
The_Grimy_One
Btw, your avatar is sick!
Old Aug 1, 2011 | 12:37 AM
Matix151's Avatar
Matix151
there most certainly should be a maxifuse for the charging system under the hood
Old Aug 1, 2011 | 01:58 AM
darthroush's Avatar
darthroush
Section Moderator
For clarification then: there was a new power wire that you added (not the OEM cable) coming off of the alternator, but not hooked to the battery, and that wire shorted out onto the cat?
