neon jsut stopped running... no sounds or anything.
Old Aug 6, 2011 | 08:30 PM
leon5366's Avatar
leon5366
Default neon jsut stopped running... no sounds or anything.
Hi.
i have a 2000 neon that just stop running as i pulled passed a light. no sounds no warning nothing, just stopped running. i got the car home and i asked around and was told the it most likely the fuel pump is clogged or just bad. So I changed it. Now It still will not run, it cranks but will not turn over. I pulled off the fuel rail and it sprays. There is still no sounds that should not be there. So I am at a lot. Any help?
Old Aug 7, 2011 | 04:55 AM
vpnavy's Avatar
vpnavy
Welcome aboard leon5366! You might want to browse Sub-Forums: Dodge Neon for stuff related to your ride.
Old Aug 7, 2011 | 04:58 AM
vpnavy's Avatar
vpnavy
Originally Posted by leon5366
...i have a 2000 neon that just stop running...
Until a member responds - did you pull the computer (OBD-II Diagnostic Trouble) code(s)? If so, what were they?
Old Aug 7, 2011 | 09:37 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I moved this thread to the second generation Neon section,
FF
Old Aug 7, 2011 | 01:37 PM
darthroush's Avatar
darthroush
Section Moderator
Do you have spark?
