trouble codes 456 and 563?
i just checked the codes on my 03 neon sxt and two codes popped up po456 and p0563 i looked them up on the obd web site p0456 is leak detected in the EVAP system and p0563 in system voltage high any thoughts or advice on what to do to fix the issues would be wonderful
thanks
thanks
P0456 small evap leak, check all the evap hose's if they are good, then replace the NVLD pump. P563
Symptom:
P0563-CHARGING SYSTEM VOLTAGE TOO HIGH
When Monitored and Set Condition:
When Monitored: With the engine running for more than 30 seconds.
Set Condition: When battery voltage is greater than 1 volt over target voltage for more
than 5 seconds.
POSSIBLE CAUSES
GENERATOR FIELD
GENERATOR FIELD DRIVER CIRCUIT SHORTED TO GROUND
TARGET VOLTAGE DIFFERS FROM BATTERY VOLTAGE
INTERMITTENT CONDITION
GENERATOR FIELD
POWERTRAIN CONTROL MODULE
TEST ACTION APPLICABILITY
1 Note: Battery must be fully charged.
Note: Generator Belt tension and condition must be checked before continuing.
Turn the ignition on.
With DRBIIIt, actuate the Generator Field Driver.
With a 12-volt test light connected to ground, backprobe the Generator Field Driver
circuit in the back of Generator Field harness connector.
Does the test light illuminate brightly and flash?
All
Yes ! Go To 2
No ! Go To 5
2 With DRBIIIt, stop all actuation.
With DRBIIIt, read the Target Charging voltage.
Is the Target Charging voltage above 13 volts?
Symptom:
than 5 seconds.
POSSIBLE CAUSES
GENERATOR FIELD
GENERATOR FIELD
All
Yes ! Go To 2
No ! Go To 5
P0456 is commonly caused by the large hose on the carbon canister forming cracks. Cold wrap tape or silicone can cure the problem.
Usually a sound system would cause a low voltage condition, not an overcharge. Sounds like something is possibly going on with the alternator.
the battery light came on for a little then i shut the car down and turned it back on and the light hasn't come on since could it have something to do with fluid levels in the battery
