01 dodge neon AT Trans problem
Old Aug 29, 2011 | 01:11 PM
Mrose1977's Avatar
Mrose1977
Default 01 dodge neon AT Trans problem
I have an 01 dodge neon... I replaced the tranny fluid and filter. (used type 4 fluid) Car drove like a dream for 2 weeks after that. I took the car on a trip to So. Cal and had no problems till I made a stop - got back in the car, put it in drive and it felt like it didn't want to move, I gave the car some gas and it shifted into gear and we were on our way! I stopped to check the fluid level and it was good... I am not getting any trouble codes... Am thinking shift solenoid but I'm not sure. Any help on this problem would be helpful.
Old Aug 29, 2011 | 01:27 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I moved this thread to the second generation Neon section,
FF
Old Aug 29, 2011 | 01:29 PM
Mrose1977's Avatar
Mrose1977
Thank you... To be honest this web site is a little tricky to figure out. Would be nice is it said "ASK A QUESTION"
Old Aug 29, 2011 | 04:32 PM
darthroush's Avatar
darthroush
Section Moderator
Since you are not getting any codes (using a code reader I hope), it may just be one of the "glitches" with these transmissions. For some odd reason after a fluid and filter change (seems to be only changing the original), the car will hesitate at random times and take a second to engage the gears. Mine does it and there have been many others asking about this.
Old Aug 29, 2011 | 05:32 PM
Mrose1977's Avatar
Mrose1977
So what do you think is the fix??? Change the fluid again???
Old Aug 29, 2011 | 06:16 PM
darthroush's Avatar
darthroush
Section Moderator
Don't know what the fix is, if there is one. I've changed my fluid and filter a couple of times since I bought the car, and it still does it. I don't think it's that big of a deal though; mine usually only needs a few seconds at most to engage the gear when it does it.
