OEM or After market?(lower arms and engine mounts)
Old Sep 6, 2011 | 04:44 PM
HEMI ?'s Avatar
HEMI ?
Default OEM or After market?(lower arms and engine mounts)
I know the OEM's control arms are decent but they fail and are a constant issue has anybody tried the aftermarket ones and how long do they last and are they any good? On the same note what about the engine mounts? I mean i have a hook-up at a dealer and can get my new arms for about 130 each but after market i can get both for the price of one? Not 100% sure about the engine mounts but i can assume the same thign as price goes their as well. Just trying to make a good decision is all any advise good or bad would be great.
Old Sep 7, 2011 | 02:45 AM
darthroush's Avatar
darthroush
Section Moderator
How do they constantly fail? That is the first time I've ever heard that.
Old Sep 7, 2011 | 05:17 PM
HEMI ?'s Avatar
HEMI ?
I did not mean they fail all the time but it seems like just about every neon out their has the issue.
Old Sep 7, 2011 | 06:56 PM
darthroush's Avatar
darthroush
Section Moderator
Do you mean the lower control arm bushings going bad?
Old Sep 7, 2011 | 09:19 PM
AnthemBassMan's Avatar
AnthemBassMan
-Just replace the bushings with Prothane or other urethane bushings. Make sure you use all of the grease they give you to avoid any squeaks. I did mine right after Thanksgiving last year. Still no squeaks, clunking or anything else from the front end. You'll notice quite an improvement over the stock, rotted rubber bushings. I got mine for around $30-$35 for the set online.
L8R,
Matt
Old Sep 21, 2011 | 02:49 PM
HEMI ?'s Avatar
HEMI ?
Yeah i ment to say the inner bushing that mount the lower arm to the frame. I did not relize i could replace just those, thouhgt i ahd to do the entire arm. I will check into that thanks!
