P0441 nvld?
Old Sep 22, 2011 | 08:06 AM
joegreen90's Avatar
joegreen90
Default P0441 nvld?
Hey all, I have a 2003 neon with a code(p0441).
I have been doing some reading on some other sites and they were saying the most common fix for this is a bad vacuum line going to the NVLD.
My question is how many lines go to the NVLD and do any go to the front of the car or just to the gas tank?
Old Sep 22, 2011 | 04:17 PM
darthroush's Avatar
darthroush
Section Moderator
I think there are two? It has been some time since I've looked around in that area. It could be either cracked lines going to the carbon canister/NVLD or the actual NVLD unit itself. I had to check and fix cracked lines to the carbon canister for an emissions code, and now intermittently I get P0441. I'm ruling it as a bad unit because it is intermittent and I know the lines are good. A bad NVLD unit isn't all that uncommon either.
Old Sep 23, 2011 | 08:02 AM
joegreen90's Avatar
joegreen90
Okay thank you i will take a look when i get the chance. Mine is not intermittent it is on 24/7.
i just lost my serpentine belt this morning on the way to work... it split down the middle.
now to find a part store to limp to and by a belt. I am going to have to check in to that.
