2000 Dodge Neon Vibration
Old Sep 28, 2011 | 11:21 PM
4SK1N's Avatar
4SK1N
Default 2000 Dodge Neon Vibration
Howdy fellers! Ok, My steering wheel feels like a jackhammer. I replaced all the mounts, upper, lower, rear, and transmission. I cleaned the Idle Air Control Valve. I sprayed starting fluid over the vacuum lines and nothing. Do you guys have any other suggestions?
Old Sep 28, 2011 | 11:26 PM
darthroush's Avatar
darthroush
Section Moderator
Was the engine mount put in the exact same spot as the old one? Were the torque struts aligned?
Old Sep 29, 2011 | 01:45 AM
4SK1N's Avatar
4SK1N
I did what u said on the rear mount Mr. Darth. I used a marker to trace it then installed the new one. On the upper I had to raise the engine to align the bolt, then lower the engine to align the lower just to get them started. On the transmission I just slapped it on. You had a diagram were the upper had to be at a measurement 119 mm and I didnt do that. It was getting dark. If I loosen the upper and lower and get the upper at that measurement do u think that will fix my problem? Thanks Mr. Darth
Old Sep 29, 2011 | 04:03 AM
darthroush's Avatar
darthroush
Section Moderator
I can't say it will fix it for sure, but it has for some people. For some odd reason, some cars just develop a vibration (like mine) and it doesn't go away. No one has been able to find a fix for those. The others...just make sure the torque struts are aligned.
