Car sputters on acceleration
Old Oct 16, 2011 | 04:00 PM
darthroush's Avatar
darthroush
Section Moderator
2gn Neons don't have a MAFS; they have a MAPS. You can test the coil with a multimeter.
https://dodgeforum.com/forum/2617980-post15.html -->
http://easyautodiagnostics.com/dodge...oil_pack_1.php
Old Oct 16, 2011 | 04:39 PM
buddhaman's Avatar
buddhaman
Wow. I didn't know we have a speed density system... Any way to convert it to MAF?
Old Oct 16, 2011 | 08:22 PM
ramzm's Avatar
ramzm
Originally Posted by buddhaman
Autozone or Advance should be able to check it for free. MAS as in mass air flow sensor? If that's what they said then you can get a can of MAF cleaner and clean it that way. DO NOT use carb/throttle body cleaner or anything oily
Yes, the Mass Air Flow Sensor. The said I could try cleaning it. Not really sure what it is, or where its at... I'll do some checking... Drove the car today and again it seemed to have no problems... Keeping my fingers crossed
Old Oct 16, 2011 | 08:27 PM
ramzm's Avatar
ramzm
Whats the difference between MAF and MAP? Do they have the same purpose? Should I clean the MAP?
Thanks for all your help darth. I read up on the link on the coil. If the sputtering comes back, the coil will be the next thing to be replaced.
Old Oct 16, 2011 | 09:16 PM
buddhaman's Avatar
buddhaman
MAP is Manifold Absolute Pressure, it measures the pressure inside the manifold rather than airflow (MAF- Mass Air Flow). MAF gives you much better performance options than MAP, at least on older systems. Not too sure how the newer systems stack up against MAF. As far as I know, you can't clean the MAP sensor, all you can do is replace it.
Old Oct 17, 2011 | 02:31 PM
ramzm's Avatar
ramzm
So far so good... Still no sputtering
