Strut replacement issue
Old Nov 12, 2011 | 12:29 AM
anglinj3's Avatar
anglinj3
Default Strut replacement issue
I have a 2002 SXT and I replaced the front struts a couple of weeks ago (Monroe Sensa-Trac). I wasn't hearing anything at first but after a little while I started to hear a grinding noise when I turned the wheel when driving at slow speeds or parked and turning the wheel back and forth. I thought the the main strut mount bolt was not completely tight. This was not the case. I found that the spring was binding, had my wife turn the wheel while I looked at the spring.
So I took the strut off again and had to rent the spring compresser a second time. I purchased a new strut mount just in case but ended up not using when looking at the old parts again. I figured the strut was not alinged properly the first time with the spring. Bad assumption...
Question, I forgot to mark where the spring was positioned relative to the strut assembly. Does this matter? I am now getting a spring/clunk noise when going over speed bumps. The noise when turning is not as bad as it was but the noise when going over speed bumps is now new. Thanks
Last edited by anglinj3; Nov 12, 2011 at 12:31 AM. Reason: Posted wrong year of car
