Rear Disc Conversion
Old Nov 12, 2011 | 06:49 PM
buddhaman's Avatar
buddhaman
Default Rear Disc Conversion
I want to convert my rear brakes to disc mainly for simplicity and I absolutely freaking hate drums. Can I just go to the junkyard and pull the front knuckle off a Neon and put it in place of my rear ones?
Old Nov 13, 2011 | 03:38 AM
darthroush's Avatar
darthroush
Section Moderator
I don't recall the fronts being the same as the rears? Get the rear knuckles. This is the parts list I found:
-Rotor
-Pads
-Caliper + Bolts
-Caliper Adapter
-Hub Assy
-Brake Lines
-E-Brake Cables
Some ppl have said they found the whole thing on Craigslist for $100. The other option is to get the knuckles from another car, and then just buy the other parts new. That's personally what I'd do.
Old Nov 13, 2011 | 04:53 AM
chew*'s Avatar
chew*
I'm in the process of doing the conversion o mine and just possibly found another R/T parts car. If i get the car I will let you know, should have everything you need
Old Nov 14, 2011 | 11:57 AM
srt4rez's Avatar
srt4rez
-Rotor
-Pads
-Caliper + Bolts
-Caliper Adapter
-Hub Assy
-Brake Lines
-E-Brake Cables
E-brake cables are among the list....if the original is used, it will not brake the emergency brakes, right? Thats why the donor cable is transferred, right?
Old Nov 14, 2011 | 03:02 PM
darthroush's Avatar
darthroush
Section Moderator
I am not positive on this answer as that is only a list that I found, not created. I'd venture to imagine that the parking brake cable is different for drums than it is for calipers. Therefore, if you have calipers, you need the cable made for them.
