back up and defroster problem
Old Nov 15, 2011 | 07:17 PM
Zanko's Avatar
Zanko
Default back up and defroster problem
Ok so I put a new bumper on my car. And the next thing I know I'm told my back up lights don't work and my rear defrost don't work either. Any ideas how to fix this would be greatly appreciated
Old Nov 16, 2011 | 10:36 AM
leprechaun1874's Avatar
leprechaun1874
I don't think the two are related. But for the lights make sure you did not pinch a wire and check the fuses.
Old Nov 28, 2011 | 09:59 AM
Zanko's Avatar
Zanko
It keeps blowing the number 7 fuse
Old Nov 28, 2011 | 04:18 PM
darthroush's Avatar
darthroush
Section Moderator
Fuse 7 is for the A/C heater blower motor. Not related to the reverse lights or rear defroster in any way AFAIK.
Old Apr 15, 2012 | 10:25 PM
Zanko's Avatar
Zanko
so i checked the fuses and I found out that the back up fuse in the side fuse panel keeps blowing as soon as I put the car in to reverse. whats messed up is it also makes my rear defroster not work as well. so im stumped on it.
Old Apr 16, 2012 | 04:31 PM
darthroush's Avatar
darthroush
Section Moderator
Have you checked the neutral safety switch wiring for a ground out/short?
Old Apr 17, 2012 | 09:43 PM
Zanko's Avatar
Zanko
I replaced the switch cause I thought it went bad and the trans filter needed changed anyways. But I will check the wires when I get a chance to.
