max HP
Old Jul 29, 2005 | 11:11 PM
DeoN44's Avatar
DeoN44
Default max HP
whats the maximum horsepower a 2nd gen neon can output without turbo?
Old Jul 29, 2005 | 11:59 PM
MChat's Avatar
MChat
Default RE: max HP
No nitrous or other "Forced Induction" either?
I don't think anyone has broken the 200whp barrier with a SOHC 2.0L Dodge engine (Magnum or otherwise). There are a few that have been close tho... It just depends on how far you want to go. The SOHC design is limited in the size of the camshaft.
Trust me... "All Motor" is code for "I want to spend ALOT of money to go 'Kind Of' fast."
Old Jul 30, 2005 | 01:59 AM
lblackneon's Avatar
lblackneon
Default RE: max HP
Sad but true.
Old Jul 30, 2005 | 02:04 AM
lblackneon's Avatar
lblackneon
Default RE: max HP
With Neons, I don't understand why u can't get an upgraded PCM and a turbo together and with a Honda u can[]. I wouldn't get a turbo on a Neon b/c you'll have to stick to the stock PCM & will be limited at 120 mph.
Old Jul 30, 2005 | 04:36 AM
casper's Avatar
casper
Default RE: max HP
All motor is not really the way to go with our cars, if you just wanna go fast. If you are looking to race in an all motor class or be able to say "I just beat your turbo honda with an all motor neon" $3500 gets you a chill factory turbo kit with intercooler. Thats a good start and will run on a stock motor with a good exhuast. That will give you about 230-250 hp depending on any other bolt ons you have. After that you have to get into the motor to up the boost more. You will also need axles at that point.
Old Jul 30, 2005 | 04:19 PM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: max HP
I know there were a few people over on neons.org that were real close to 200 whp. Turbo would be cheaper then all motor for sure.
