governor restriction
Old Aug 8, 2005 | 01:02 AM
lblackneon's Avatar
lblackneon
Default RE: governor restriction
I was going to say; since you have an 02' the easiest thing to do is get a reprogrammed PCM from Howell but, for 02' they only have it for the manual. I wonder why that is.
Old Aug 8, 2005 | 06:38 PM
litbic's Avatar
litbic
You should just get the R/T model as it rev limits at like 7200 and it dosen't have govoner. I have hit speeds over 125mph. However, just because the speedometer goes to 120 on your car dosen't mean that the car goes that fast.
Old Oct 13, 2005 | 06:20 AM
nickoman01's Avatar
nickoman01
The Only Elite DF Member
in my 03 auto my neon wouldn't go over 105 unless i was going downhill. it pissed me off. it should of been able to do more.
Old Oct 14, 2005 | 07:52 AM
casper's Avatar
casper
You can either put a switch in or cut the spedo wire to the PCM. However if you do cut it, your spedo will not work. If you switch it it won't work when you flip the switch, but it will give you an unlimited top speed. The same applies for the rev limiter. Now this will affest your performance is I do not recomend it for the rev limiter, but the speed limiter is free game.
Old Oct 14, 2005 | 02:44 PM
CleanNeon's Avatar
CleanNeon
The car with an auto will easily go past 103. As for the car having an unlimited top speed. I think Csper means unlimited until the gearts run out and you really hit the rev limit, not the rev limiter but the rev limit.
Old Oct 14, 2005 | 07:58 PM
casper's Avatar
casper
ORIGINAL: CleanNeon
Yeah, lol, by unlimited I meant that there will be no govener or speed cut out. I doubt that you will hit the rev limiter either, the motor in its stock form does not have enough power to hit the rev limiter in final gear.
Old Oct 28, 2005 | 06:37 AM
TSchott's Avatar
TSchott
Alright I'm new to this site and I own a 2005 Dodge Neon SXT (AUTOMATIC) which I bought on July 27th, 2005 and I have zero mods done to it however as for this posting I can get approximently 115 on the freeways, I will have some specs about my car some time soon just not there yet!
Old Oct 30, 2005 | 03:47 AM
bebi_wilson's Avatar
bebi_wilson
I have had my 01 R/T to 121 mph on the highway. Does anybody know how fast an R/T can go completly topped out?
Old Oct 30, 2005 | 03:19 PM
casper's Avatar
casper
ORIGINAL: bebi_wilson
You should be able to hit 125mph on a straight in stock form.
Old Oct 31, 2005 | 01:54 PM
04Dodge.Perf.'s Avatar
04Dodge.Perf.
Is it me or is it between the speeds from 100 to 110 it takes forever. I have a cold air intake and the second I hit about 100-102 my car goes silent. I can barely hear my intake, my exhaust, and my engine. I find it wierd that the car still goes to 118. That was my top speed also in my 04 Dodge Neon (Automatic)[:@]
