quarter million
Old Dec 4, 2011 | 12:01 AM
me0418840987's Avatar
me0418840987
Default quarter million
Just for fun, I rolled 250,000 miles today, actually, 250,610. Just fluid changes on time and basic maint-no tinkering/modding
Old Dec 4, 2011 | 03:12 AM
darthroush's Avatar
darthroush
Section Moderator
Congrats! Amazing how long a car will last when simple preventative maintenance is done when it should be.
Old Dec 4, 2011 | 10:42 PM
earlyre's Avatar
earlyre
have an uncle that did 300k in his 95 Bonneville SSEi (Supercharged 3.8l), then "cash for clunker"ed it.
just kept up on the basics. nothin' fancy.
dang, i just turned 70k tonight....
Old Dec 4, 2011 | 11:10 PM
darthroush's Avatar
darthroush
Section Moderator
I'm almost to 140K. Bought the car with 73K in September of 2008. No problems except a CEL again for a small EVAP leak. Probably one of those carbon canister hoses again.
Old Dec 4, 2011 | 11:22 PM
me0418840987
Well, I can't say I haven't had my share of problems, Mother's mechanic changed trans fluid with dex-III, and led to the enevitable at about 89,000 miles or so, that was expensive $2800. 3 pair of rear wheel bearings, bushings, motor mounts, 2 oe radiators- when I got it, I bypassed the trans cooler completely-no more problems with that. Currently running a $26.00+ free shipping ebay radiator from a manual trans car- 70,000 miles and still holds water. My recent evap leak WAS actually the gas cap-no kidding.
Old Dec 5, 2011 | 04:37 AM
darthroush's Avatar
darthroush
Section Moderator
I'm going to check the EVAP lines once more, and then if it still isn't gone, the gas cap is what would be left. Just came out of the blue...go figure.
I've replaced many things on my Neon too, however, they were wear and tear items that previous owners didn't replace. The only real problems I've had are the transmission oil pump going out and needing a new solenoid pack.
Old Dec 11, 2011 | 11:06 PM
me0418840987
I have actually decided that the selonoid packs on dodge fwd autos are general maintenance items. 2 on the Neon, 1 on my G Voyager, at least 1 on every other DodgeFWD we have owned. Pair of rear struts, Driver seat from junkyard, serp belt tensioner assembly- another brilliant engineering design- $300+ part from the dealer. Lots of little things, that if you do them as they come along, it isn't as big of a hit compared to letting it all go and then junking the car because you don't want to sink $4,500 into it to keep it on the road. The body cancer has started to creep in, I just found a fist sized hole on the rocker panel under the rear driver side door. Fastest rotting vehicle I have had besides my '72 Jeep pickup- that thing, I swear, was rusting away on the assembly line.
