Cam Position Code Help Needed
Old Dec 10, 2011 | 08:01 PM
bdanko211's Avatar
bdanko211
Default Cam Position Code Help Needed
Previously my car had thrown a cam posistion code after stalling out at a light, the next day i changed the sensor and then changed the spark plugs. car does not stall at light but maintaines rough idle while in drive, it still throws the cam position code at lights, so i replaced the sensor again. Presently it is still throwing the cam position code and still maintaining a rough idle need help on what to do next... cannot think of any other ideas
any help or advice is appreciated
Old Dec 11, 2011 | 04:56 AM
darthroush's Avatar
darthroush
Section Moderator
Is the sensor wiring good? No broken or grounded out wires? If the wiring is bad, you can replace the sensor a million times, but it still won't ever work right.
