2.0 head help
Old Dec 14, 2011 | 04:46 PM
brokeneon88's Avatar
brokeneon88
Default 2.0 head help
is the heads different between a 2000 and 2003rt neon, i have a head off the rt and just bought the 2000 that broke timing belt which im guessing the valves are bent then. so i was going to switch the heads and resell the 2000 and make a buck. thanks for your time
Old Dec 14, 2011 | 06:18 PM
darthroush's Avatar
darthroush
Section Moderator
If both are an R/T, then yes, they should be the same.
Old Dec 14, 2011 | 06:40 PM
brokeneon88
no its a regular 2.0 im guessing there the same
Old Dec 15, 2011 | 01:24 AM
darthroush's Avatar
darthroush
Section Moderator
The R/T's have a DOHC engine. Re-read my post. If they are both R/T's, then they should be the same. Meaning: if they are not both an R/T, they are not the same.
