Clunk when turning
Old Feb 6, 2012 | 12:32 AM
rfw0002's Avatar
rfw0002
Default Clunk when turning
I have a 2005 stx around 80k. I had the lower control arm bushings replaced and most of the front end noise is gone. I still hear a clunk when the lt front traveles over a bump. I can turn the steering wheel when stopped and
hear the lt front susp clunk. Does this sound like an outer tie rod or possible swaybar bushing issue?
Rob
Old Feb 6, 2012 | 12:54 AM
darthroush's Avatar
darthroush
Section Moderator
You should check both of those.
Old Feb 6, 2012 | 10:13 PM
buddhaman's Avatar
buddhaman
Did you have the lower ball joint done?
