I need help with my neon's EVAP system
Old Apr 23, 2012 | 10:47 PM
2003 Dodge Neon Sxt's Avatar
2003 Dodge Neon Sxt
Got a 2003 Dodge Neon Sxt 2.0 automatic, check engine light is on and says P0455 Done! So we were told it needed a gas cap, had a new one put on and the light never came on till we drove about 300 miles. Weve been told it could be a canister purge solenoid but i did some research on here and people are saying they had problems with the natural vaccum leak detection? Any idea's???
Old Apr 24, 2012 | 02:04 AM
dinwiddie1985's Avatar
dinwiddie1985
It is possible, but I got codes 0456 and 0452 i believe and both are EVAP leak codes. I changed every part involved in the EVAP system and the check engine light is still on, so I have no clue
Old Apr 24, 2012 | 02:40 PM
2003 Dodge Neon Sxt
Default 2003 Dodge Neon Sxt P0455 CEL code......Please Help Someone...
We have a 2003 dodge neon sxt. CEL is on and code says P0455 Done! Hooked a scanner up to it and it says it was a large leak in the EVAP system. Bought a new gas cap and that didnt work. I was told it was the purge solenoid and if it was i would have got the code P0443 which is the purge solenoid engine code. Where is the purge solenoid located so i can check the hoses and is anyone sure what it could be for sure???
Old Apr 24, 2012 | 04:21 PM
2003 Dodge Neon Sxt
Where is the Purge Solenoid located on a 2003 Dodge Neon Sxt?
Old Apr 24, 2012 | 07:29 PM
darthroush's Avatar
darthroush
Section Moderator
Right side on the firewall in the engine bay nearish the bottom.
Old Apr 24, 2012 | 11:45 PM
2003 Dodge Neon Sxt
Thanks, i actually found it earlier. But i have a feeling that its not the purge solenoid. P0443 is purge solenoid code but the car is saying P0455 code which is a large leak in the emission system, any idea's???
Old Apr 25, 2012 | 12:57 AM
darthroush's Avatar
darthroush
Section Moderator
Besides there being a cracked hose or something in the emissions system, it could be either the purge solenoid operation or the NVLD switch operation.
Perform a visual and physical inspection of the entire Evaporative Emission system.
Check for the follow conditions:
- Holes or cracks
- Loose seal points
- Evidence of damaged components
- Incorrect routing of hoses and tubes
- Fuel Cap gasket seal
Old Oct 23, 2012 | 01:32 PM
Kayla Heffernan-Sweat's Avatar
I have changed the gas cap twice in my 2005 dodge neon and the check engine light is still reading a leak. They told me to take it and check the EVAP system. Has anyone else had this problem and if so what are some suggestions to fix this problem. I have had to fix multiple problems already this year.
Old Oct 25, 2012 | 02:56 AM
darthroush's Avatar
darthroush
Section Moderator
Look at the post right above yours
