check engine codes
Old Aug 8, 2005 | 11:37 PM
szins26's Avatar
szins26
Default check engine codes
okay im new to thsi but i have a 03 neon se and just the other day check engine light came on and now my car is acting as if the transmission is gone. it will work for a few seconds then just rev so i did the ignition thing 5 times and it gave me p0456 and p0700 is this really expensive amd i going to need a new transmission it says in the codes for P0700 Transmission Control System Malfunction and for P0456 A small leak has been detected in the evaporative system! any ideas or helpful info would be appreciated.
Old Feb 20, 2008 | 10:57 PM
trojanknight85's Avatar
trojanknight85
Default RE: check engine codes
as far as the evaporative leak i was told by a mechanic i trust that it is not a major issue it just means that your gas cap is not sealed well. i currently have the same problem with my car on the P0700 transmission control system failure. i am guessing that you have over 70,000 mi because the dodge neon se have a transmission that gives out around that time. the only answer is to replace it especially if you have been feeling the gears slip or lessen in power.
I need some advice on what transmission to buy i wanna find performance and quality without killing my wallet. if anybody had any recommendations please let me know.
Old Feb 20, 2008 | 11:00 PM
neon03se's Avatar
neon03se
p0456 could also be a crack in the fuel lines. check them. as far as the transmission, i have no idea hopefully someone else can chime in. I'm assuming your cars are manual?
Old Feb 21, 2008 | 08:36 PM
bone33's Avatar
bone33
you guys with tranny problems need to change the filter and replace the fluid with ATF+4 before you decide to get a new tranny. 70,000 miles is not alot of miles and im sure your trans is not fried.
Old Feb 21, 2008 | 10:16 PM
HarleyRider68's Avatar
HarleyRider68
ORIGINAL: bone33
I agree, change the fluid and filter. Carefully examine the old fluid and look in the pan for particles or other evidence of internal damage. If the fluid is scorched, that's a bad sign.
Old Feb 23, 2008 | 06:37 PM
Skyelight22's Avatar
Skyelight22
I threw the same transmission code and I have 27,000 miles, I erase the codes and it dont come up anymore.
