01 dodge neon fuse panel diagram/picture
Old Mar 30, 2012 | 11:56 AM
jord712's Avatar
jord712
Default 01 dodge neon fuse panel diagram/picture
I have a 01 dodge neon its the base model with crank windows and manual locks. I have started the process of converting it to power options. I would like everything to appear like it came from the factory with the power options, so I would like to draw power from the factory locations in the fuse box. Does anyone have a diagram or picture of a 01 neon that has power options, so I can see where to hook them up at?
Old Mar 30, 2012 | 04:27 PM
darthroush's Avatar
darthroush
Section Moderator
https://dodgeforum.com/forum/1455677-post7.html
Old Mar 31, 2012 | 11:21 AM
jord712's Avatar
jord712
I can read it good thank you. But I see a spot for power windows and door locks. Just mirrors, do you think they are all the same fuse.
jord712's Avatar
jord712
I dont see a spot for power windows and locks**
Old Mar 31, 2012 | 03:48 PM
darthroush's Avatar
darthroush
Section Moderator
There's P/WDO at the top. To me, that sounds like it could be Power Window. Either that, or those fuses might be in the PDC in the engine bay.
Old Mar 31, 2012 | 10:54 PM
jord712's Avatar
jord712
O i see it thank you for pointing that out
do you know anyone that has ever done this power conversion like i am doing?
Old Mar 31, 2012 | 11:03 PM
jord712's Avatar
jord712
Also do you think that p/wdo is just for windows or do you think the power locks would be on that one also?
