Use key of same model
Old May 27, 2012 | 01:43 AM
muzokh's Avatar
muzokh
Default Use key of same model
Hello All
I need you advise, I have 2 Dodge 2005 SX2 cars, one of them is totally lost so I want to use this total lost car key with my my other same model dodge, how can I achieve this goal. Thanks
Regards
Muzokh
Old May 27, 2012 | 03:26 AM
fhadso's Avatar
fhadso
I don't think you can. Assuming they have differently keyed ignitions, it would be nearly impossible. If you were a professional locksmith, you could re-key the car you have.
Old May 27, 2012 | 07:17 AM
muzokh's Avatar
muzokh
Thanks for your advise. I really appreciate it. Actually I wanna make another copy of my keys and I went to Dodge dealership and they told me that they can charge around $225 for just a key. is there any cheaper solution for making duplicate key.
Old May 28, 2012 | 04:19 PM
fhadso's Avatar
fhadso
Yes. Assuming you don't have a chipped key, you can get a copy made at Walmart for around $3. If you have a chipped key, you will hjave to buy a blank chipped key from eBay, and then reprogram the key, which is very easy to do and there are many tutorials on how to do that. The chipped key is a computer chip inside the key that will only work in one car.
Old May 28, 2012 | 06:49 PM
muzokh's Avatar
muzokh
Thanks for the reply. Please tell me one more thing, I need to buy some specific blank chipped key from ebay or any.
Old May 28, 2012 | 10:40 PM
Moparkyle's Avatar
Moparkyle
Was your original key Black or Grey?
Old May 28, 2012 | 10:44 PM
Moparkyle's Avatar
Moparkyle
http://www.wjjeeps.com/sentry.htm
I hope that article helps, Neons use the same system..
Old May 30, 2012 | 11:13 PM
muzokh's Avatar
muzokh
Thanks for the replies, the color of my original key is like a brown or gray but I am sure its not black. In addition, I read the article and as per article, I need two original keys in order to create another or duplicate key and I have only one key. Please suggest.
Further more, I browsed through ebay.ca and found the below key. could you please confirm it that I can order it or not.
http://www.ebay.ca/itm/CHRYSLER-IGNI...item33686e5bb0
Regards
Zuhair
Old May 31, 2012 | 07:03 PM
Moparkyle's Avatar
Moparkyle
That key should work.. you could get the key cut somewhere else, but I think you would have to return to the dealer for them to program it since you only have 1 original key.
I've been wrong before though.
Old Jul 23, 2012 | 08:12 AM
Amery's Avatar
Amery
I don't think so the key of same model works if the key of your car lost or stolen,.
I such case only lock smith helps,.
24 hour locksmith nyc
