A/C Question
Old Jun 6, 2012 | 11:22 PM
fhadso's Avatar
fhadso
I'm missing power. The control switch appears to be a "non-ac" version. Like maybe the original went out and seeing as the A/C didn't work anyway, the PO just put in the cheaper one.
Old Jun 7, 2012 | 05:52 PM
fhadso's Avatar
fhadso
Update: Ok so it wasn't the control switch. Next step is the blower resistor. I'm going to have my mechanic look at it tomorrow to see exactly what it is.
Old Jun 8, 2012 | 07:36 PM
TejasMtnBiker's Avatar
TejasMtnBiker
don't give up yet, try swapping out one of the relays in the fuse box with a smililar one that works. do you use a test light to check for continuity on the wire's from the compressor, with the a/c fan on inside the car?
Old Jun 9, 2012 | 01:21 AM
fhadso's Avatar
fhadso
I tested the a/c wire in the connector for the control switch. It isn't getting power. I read my wiring diagram from my haynes manual that power goes to the low pressure, then the high pressure, and THEN the control switch.
Old Jun 13, 2012 | 11:18 AM
TejasMtnBiker
has the front end been wrecked before if you know of? Down by the computer left front driver side behind the bumper I can't remember or not if one of the power wires comes from that harness but you might take a look for damage to the wiring, wish you lived close by we'd have it done last weekend
Old Jun 17, 2012 | 10:39 PM
v793jt0's Avatar
v793jt0
Default 2002 Dodge Neon A/C
Can you install A/C on a non/A/C dodge neon 02 ? or Does anyone know where to get the best price on parts for this, like a complete a.c kit?
Old Jun 19, 2012 | 12:14 AM
fhadso's Avatar
fhadso
It would probably be better to make a separate thread for this.
Old Jun 19, 2012 | 07:26 PM
Moparkyle's Avatar
Moparkyle
Did you ever find your problem?
Old Jun 20, 2012 | 01:54 AM
fhadso's Avatar
fhadso
Well, no. But I did find out that I need a new condenser. The compressor still doesn't click in even with the new high and low pressure switches are installed. I found out that even after jumping the compressor, I don't have cold air unless the radiator fan is engaged. I'm going to take it to a specialist sometime to get it completely fixed.
Thus far, I've replaced the high pressure line, compressor, high and low pressure cycling switch, and in-dash control switch. I don't have a freon leak anywhere, so it's not any of that. I've definitely got it nailed down to an electrical problem.
