Cam shaft for a SOHC?
Old Jun 24, 2012 | 07:09 AM
Trialmaster's Avatar
Trialmaster
I hate turbo, and love na, but its å litle tricky with na. That make it more interesting. You can bolt å turbo to anything, and the horses come runing. In na, YOU have to hunt them down!
Thats the deal, folks
Old Jun 24, 2012 | 01:57 PM
TaterTodd's Avatar
TaterTodd
thanks for the info on the difference concerning the cams ... that'll be valuable info when I get around to redoing my 2.0 ...
Old Jun 25, 2012 | 07:16 AM
Trialmaster
When you have the top off, you can do a mild exhaust p&p. Just smouth out the step that are located just under the valve. I used a air tool to do it + som sanding and polishing. The big water jacket hump all of us hate, can you just leave allone, with that cam and standard rpm limiter. Do a magnum swap instead, if you are going for higher levels.
If its legal in your state, switch to a full TTI exhaust system with LTH.
It gains you some 10 Norwegian stallions with a TTI allone
Old Jun 25, 2012 | 07:42 AM
Trialmaster
Dont forget a 3 angle valve job and .030 planing B)
