2005 SXT not starting.
Old Jul 16, 2012 | 08:25 PM
Goromous's Avatar
Goromous
Gotcha. Checked fuel today as well as replacing spark plugs. Fuel is looking great. Plan on testing spark as soon as I get someone to help.
Old Jul 16, 2012 | 11:13 PM
Moparkyle's Avatar
Moparkyle
Does it sound like it is a slow crank or does it sound like it is spinning faster? A jumped tooth on the timing will cause a weird sounding crank and low compression.
I found a video of a jumped tooth. (skipped to 7:40)
Old Jul 17, 2012 | 03:51 AM
fhadso's Avatar
fhadso
Honestly, it sounds like a timing belt issue. It won't start after it fails, and it will crack slowly, almost as if it doesn't have compression.
Old Jul 17, 2012 | 11:12 AM
Goromous's Avatar
Goromous
I was thinking the same thing. I've watched a few videos on how to change the timing belt, but not 100% sure if this is something I want to tackle by myself. Do you suggest I hire someone to do it?
Old Jul 17, 2012 | 07:32 PM
Moparkyle's Avatar
Moparkyle
I'm not sure how well you can see with these engines but usually a quick easy test is to take off the oil filler cap and have someone crank the engine while you see if the cam turns with the engine.
Old Jul 18, 2012 | 01:47 AM
fhadso's Avatar
fhadso
I know that on my neon, there is a "baffle plate" just below the oil filler, so I don't think you can see it move.
Old Aug 7, 2012 | 01:33 AM
Goromous's Avatar
Goromous
Update: Turns out that it wasn't the timing belt at all. The brand new alternator I installed froze up a few weeks after installing, which wouldn't let the crankshaft turn at all.
So basically I spent a ton of time and money chasing a ghost.
Oh well, live and learn, off to get a new alternator!
