ATX to MTX
Old Jul 20, 2012 | 03:32 PM
jw11432's Avatar
jw11432
Default ATX to MTX
Been searching through older threads, and I feel like I need to ask questions more directly than what I'm finding in these threads, so I apologize if this info is in fact somewhere else, and I didn't see it.
1) Will ATX pcm work with MTX? Just recently bought this reman. pcm and i would hate to have to replace it for a different one; if it is necessary, would I at least be able to have it reprogrammed/reflashed to work for a MTX?
2) Which years of neon would be the smoothest transition (in terms of replacing the least amount of other components to make everything work) for a donor MTX? (mine is a 2000)
thanks guys..my ATX is shifting great after my rebuild, but it really feels like it should have a manual shifter, the ATX just seems to be killing its capability, lol
Old Jul 21, 2012 | 10:00 PM
buddhaman's Avatar
buddhaman
2000 would be the best since it's a cable clutch system. Any years after that(I believe) are hydraulic so you'd have to do some work with the firewall. As for the PCM, The ATX PCM has a rev limiter of 6,700 RPM whereas the MTX has a higher limiter.
Old Jul 23, 2012 | 01:15 AM
jw11432's Avatar
jw11432
cool..thanks for the info!
