help to mount aem CAI and MPX throttle body
its easy, what exactly are u having problems with? and what hoses do u need help with?
to connect the intake tube with the mpx tbdy, just use the supplied aem rubber insulators to make a snug fit from one tube end to another.
[IMG]local://upfiles/16963/207E3CEB7A064FB28E8AED9557EBFEAE.jpg[/IMG]
Ok, I know this must be easy! I still dn't know where and which hose I have to connect and where..
Ok, I have 1 thin plastic tube coming from the valve cover breather, so just behind the ingnition coil. Normally it must go to the throttle body. But with the MPX Throttle one you just have 1 metalic pipe on its side and the diameters are not the same. Well I imagine I can put it with a clanp, but this seems strange to me.
The second thin plastic tube is coming from the power break. Should I connect it to the Air inlet? But it's so short about 20 cm...and when I see pics on Modern Performance website, the all have a big rubber tube going to the valve cover......
See the pics.
See the pics.
