p1390 once warm
Old Jul 25, 2012 | 07:10 PM
tnginc's Avatar
tnginc
Default p1390 once warm
Ok so I have a 2001 neon that will throw p1390 after the motor warms us. I have checked and rechecked the timing and it is good... any ideas? I am stumped.
Old Jul 26, 2012 | 06:59 PM
jw11432's Avatar
jw11432
so everytime it's cold, the code is not there? only after it warms up, the code will pop up? (or check engine light, rather)
Old Jul 27, 2012 | 04:52 PM
tnginc's Avatar
tnginc
exactly. once I clear the code and let motor get cold, I restart and as soon as motor hits op tem the cel comes on and I have p1309.
Old Jul 27, 2012 | 05:16 PM
jw11432's Avatar
jw11432
perhaps a failing timing belt tensioner. as it warms up, it could be weakening, causing that particular code to throw. only other thing I can think of to check is make sure the dowel on the cam gear hasn't sheared, and since the cam position sensors are so cheap and relatively easy to get to, that might be worth replacing for the hell of it. perhaps it is going bad in such a way it's not throwing a code, but causing a faulty reading elsewhere. that's all ive got at this point.
Old Aug 1, 2012 | 04:10 PM
tnginc's Avatar
tnginc
thanks, I will take a look and see what I find. I did put in a new tensioner when I replaced the belt.
Old Aug 1, 2012 | 10:40 PM
Moparkyle's Avatar
Moparkyle
Camshaft sensors sometimes have problems when they get warm, If you had a scantool you could monitor the signal, but without one it gets a little hairy.
