O2 sensor--ULEV, LEV????
Old Jul 26, 2012 | 03:52 PM
jw11432's Avatar
jw11432
Default O2 sensor--ULEV, LEV????
in my manual, as best as I can tell, if my post cat O2 sensor is located after the cat, and doesnt thread into the cat's shell, then I have a regular emissions system, not a ULEV or even a LEV, so I would need the O2 sensor labeled as "all except ULEV". am I right on this assessment?
Old Jul 26, 2012 | 08:38 PM
WalkerTech's Avatar
WalkerTech
Jw, I am a Product Specialist with Walker Products, a manufacturer and worldwide distributor of oxygen sensors. It would help if I knew what year of Neon you drive and what engine you have.
Old Jul 26, 2012 | 10:38 PM
jw11432's Avatar
jw11432
that's odd, i could've sworn my signature, or something like that automatically showed what i had.
anywho, thank you for your reply! it's a 2000 dodge neon, with SOHC 2.0L, ATX.
Old Jul 27, 2012 | 06:09 AM
darthroush's Avatar
darthroush
Section Moderator
The ULEV Neon was only made in early 2000, and if you have it, you will the regular cat and a smaller one at the end of the exhaust manifold along with (I believe) a third O2 sensor.
EDIT 1: I found a post of mine from some time back where I typed LEV Neons only have one O2 sensor? Not sure where I found that....
EDIT 2: This is the emissions/cat/O2 sensor diagram from the 2000 Neon Factory Shop Manual
Old Jul 27, 2012 | 04:05 PM
jw11432's Avatar
jw11432
yeah, ive seen that pic in my FSM. I didn't look at my options at autozone clearly enough, it seems there are in fact only 2 different types; ULEV and all except ULEV. So I did in fact get the right one, I was thinking for some reason there was a third option. Good to know the ULEV is as scarce as it is, cuz I imagine it's quite a pain!
Old Jul 28, 2012 | 04:07 AM
darthroush's Avatar
darthroush
Section Moderator
Just an extra cat. Still stoopid though.
