A/C problem, very strange
Old Aug 19, 2012 | 04:46 PM
jw11432's Avatar
jw11432
Default A/C problem, very strange
Here's the kicker; everything is new. Evaporator core, expansion valve, drier, condensor, compressor, low and high pressure cut out switches. did the FSM specified test on the expansion valve, and it checked out. before starting, i added as close to what i could get to the 6.1 oz of pag 46 (certainly did not overfill, if it's over, it's by the slightest amount, and my problem should not be attributed to such a slight overfill; even still some oil was taken out, and it still isn't working right...unless these systems are CRAZY sensitive to oil increments?) and the 1/4 oz of UV dye. put the vacuum on, and it got down to the -28 in hg and held for about 10 mins, so we added freon. here's where it gets wonky.
getting to the specified pressure, per the FSM, is achieved before the full 27 oz of freon are put in. i believe we got in not even half of that before the blow off valve on the compressor let out. after that, though pressures are right on the gauge (manifold gauge set, not the single plastic one on cheapy cans), there is not the specified amount of freon in the system, and of course, not cooling. ruled out blend door problem, as low side line is ambient temp to the touch, not cold or sweating. also, what happens is if the pressures are achieved, gauges show the pressures will build gradually, just from the car idling; decent fan in front of the car, and on board fans working properly.
what the hell is going on here?!?
Old Aug 19, 2012 | 11:39 PM
earlyre's Avatar
earlyre
ok, first things first.
you keep saying Freon. are you actually using Freon(r-12), or what you should be using (r-134a). I believe i read that r-12 will damage seals and what not in systems designed for r-134a.
Old Aug 20, 2012 | 02:30 AM
jw11432's Avatar
jw11432
i say freon as a generic term; i am using r-134a, straight; none of that stuff that has the stop leak, or 'super cold' additives.
Old Aug 20, 2012 | 03:41 PM
earlyre's Avatar
earlyre
no worries man, just wanted to be sure.
Old Aug 22, 2012 | 04:17 PM
jw11432's Avatar
jw11432
No ones got anything? Guess its time to pay an ac expert then.
