My oil drain bolt wont tighten all the way onto my oil pan. Can i just throw some threadlock in there and call it a day or get a new drain bolt or oil pan?
thanks.
thanks.
I'm assuming it's stripped out? If that's the case you have 4 options..
1.If you're lucky the threads are only bad on the plug, get a new plug and see
2. By an oversized plug (be gentle with it)
3. They sell kits to helicoil the pan.
4. Replace pan and plug (usually least preferred)
Quote:
1. If you're lucky the threads are only bad on the plug, get a new plug and see
Agreed. Originally Posted by Moparkyle
I'm assuming it's stripped out? If that's the case you have 4 options..1. If you're lucky the threads are only bad on the plug, get a new plug and see
Replacing the pan on these cars is ridiculously easy though...messy, but really easy.
