Bent valves
Old Aug 30, 2012 | 01:03 PM
Oscar Sanchez's Avatar
Oscar Sanchez
Default Bent valves
I can only see in the pistons that 8 valves hit but i took the head to a machine shop and they said that i had 8 bent valves. When i got there they told me that also the other 8 were bent. I smell something fishy going on
Old Aug 30, 2012 | 11:13 PM
Moparkyle's Avatar
Moparkyle
Just because you don't see where they hit the piston doesn't mean that they might not be bent.
Old Aug 30, 2012 | 11:45 PM
fhadso's Avatar
fhadso
When my timing belt went, I thought it was just 8 on cylinders 2 and 3. It was all 16. even if they aren't bent, it doesn't hurt to replace them all seeing as they're relatively cheap.
Old Aug 31, 2012 | 06:59 AM
Moparkyle's Avatar
Moparkyle
^^ +1
Old Aug 31, 2012 | 10:23 AM
Oscar Sanchez
machine shop is charging me 210$ for all the 16 valves plus labor 350 total
Old Aug 31, 2012 | 03:58 PM
fhadso's Avatar
fhadso
Don't repair the valves. Get them replaced. Cheaper that way.
Old Aug 31, 2012 | 08:33 PM
Arsenal_619's Avatar
Arsenal_619
You didn't say what kind of car you have so I'll use mine as an example.
04 Dodge Neon
2.0L SOHC
Rockauto.com
Exhaust Valves at $10.89 each for a total of $87.12 for 8
Intake Valves at $8.37 each for a total of $66.96 for 8
Valve Guides at $3.85 each for a total of $61.60 for 16
Pack of 16 Valve Stem Seals for a total of $21.79
Total cost of Valve replacement $237.47
If the shop is charging you $210 just to replace the valves but not the guides and stem seals then they are ripping you off.
Old Aug 31, 2012 | 09:20 PM
Moparkyle's Avatar
Moparkyle
The shop charges mark up on parts.. it's how they make money.
Old Aug 31, 2012 | 11:28 PM
Arsenal_619
Then your going to the wrong shop, out here in San Diego the shops charge you what the part cost. They don't mark them up where they get you is the 90 hr labor. I know shops that let you buy your own parts and they'll install them and just charge you labor.
Old Sep 1, 2012 | 03:38 AM
darthroush's Avatar
darthroush
Section Moderator
You will generally be able to get parts cheaper on the internet/RockAuto than you will get from a parts store (which is where shops get their parts from). I haven't ever had a shop mark-up parts on me, especially if I am paying them to replace them on my car. Then again, I tend to buy my own parts and simply pay for labor if it's something I don't want to deal with.
