Firing on two cylinders
Before changing the Ignition Coil I would of bought a new set of Spark Plug Cables. Try new cables.
Also to check to see if the cables are good you can pull them out and place a piece of metal at the end and see if there's a spark. If there is then you know the cable is good and it could be the spark plug.
