2004 SXT Overheating
Hello, I have a 2004 Dodge Neon SXT, around 153k miles, that i'm having issues with. It is overheating when I'm driving for long distances on the highway, but fine around town. I drive back and forth between my parents house and my house, which is 6 hours away. What is happening I can drive for about 3-4 hours going roughly 70 mph and it then the temperature will just slowly start to rise. I can turn on the heat full blast and it will drop my temp but pretty much as soon as I turn my heat off it will start to climb again. The fans are working correctly and I changed the thermostat this past winter, roughly 8 months ago. I just had my coolent flushed thinking it would take care of the problem since the coolent was just nasty rusty looking. The fluid is now clean with a little bit of brown specks in it. So I'm just wondering if it would be radiator just so corroded? Do I need to replace this, or could it be something else, like a blown head gasket. I haven't noticed any coolent in my oil and vice versa and haven't noticed coolent loss, besides what boils out of the resevor when it overheats and I stop. I'm at the end of my rope on this car and about to just trade it in even tho I love it, lol.
- Open the radiator cap (Do not open it when the engine is hot, or you will get burn).
- Start your engine, and let it idle.
- Turn the heater on.
If the system has air in it, this will let air out.
You just need to fix the heating issue, and your transmission will shift smooth again.
You can run a little lean I think, but the temperature shouldn't rise up continually like that. The engine would ping before that happen.
If other mechanical failures like blow head gasket, the engine wouldn't start up right away, and run smooth like that.
