what causes P1193 Inlet Air Temp Sensor Voltage High??
Old Sep 14, 2012 | 08:00 PM
Oscar Sanchez's Avatar
Oscar Sanchez
Default what causes P1193 Inlet Air Temp Sensor Voltage High??
recently replaced valves an cam position sensor and all of the previous codes disappeared and now am getting this? any idea on how to fix?
Old Sep 14, 2012 | 08:45 PM
cheapez's Avatar
cheapez
I didn't know the answer to your question, but I did some research, and this is what I found:
Posted by: Mr one world
forum. 2gn. org/viewtopic.php?t=57777&sid=82ef5a75fc7663521911b8b3 ba56c850
Is your battery light on also?
On cars with no battery blanket sensor, the AIT sensor acts as both air intake temp, and ambient temp. When mine was unplugged, I got a battery light. The alternator will still charge, but at a fixed 13 volts, or something close to that.
P1193 is temp circuit low voltage. Not sure what the correlation is to actual sensed temperature, if it is low temp, your alternator may be putting out too high of a voltage for the ambient temps. Too high, it may be lower, or it has defaulted to the 13 volts.
If you have a voltmeter, I would check to see where it is. 14.5 volts won't really hurt much, unless the temps there get very hot. If the battery is good, it shouldn't go much over 15ish volts anyways. You would know if it was going higher. Your headlights would have excellent output
