Burning Oil
Old Nov 30, 2012 | 03:33 PM
  #21
TejasMtnBiker's Avatar
TejasMtnBiker
before too long that much burning up will clog a cat I'd assume O.o
Old Dec 1, 2012 | 12:09 AM
  #22
Moparkyle's Avatar
Moparkyle
Well unfortunately other than external leaks there aren't really very many places oil can be lost inside the engine.
Either you have bad rings (which should show up on a compression test), or you have some bad valve seals.
Regardless it probably means some engine repair.
Old Dec 1, 2012 | 05:20 PM
  #23
George Dorn's Avatar
George Dorn
Spark plug #3 was fouled beyond belief; barnacles of white with sludge visible in the chamber.
And the compression test results are in:
Dry
1 - 150
2 - 175
3 - 150
4 - 175
Wet
1 - 175
2 - 235
3 - 175
4 - 235
Cool story bro. Can an experienced mechanic explain this to me? This is the first time I've ever done it.
Old Dec 1, 2012 | 06:59 PM
  #24
cheapez's Avatar
cheapez
He didn't has breakfast that morning.
That is 15% different right there.
Old Dec 2, 2012 | 12:55 PM
  #25
Moparkyle's Avatar
Moparkyle
If the compression readings improve with a wet test, it generally means the rings are worn and the oil you put in the cylinder helped seal them. 235 seems a little high though, how much oil did you add before you did the test? lol
Old Dec 2, 2012 | 07:20 PM
  #26
richards83's Avatar
richards83
Did you rig the throttle wide open and pull the ASD relay to kill the injectors when you did the compression test? You'll get inaccurate readings if you don't.
Old Dec 3, 2012 | 02:48 AM
  #27
darthroush's Avatar
darthroush
Section Moderator
Good points! That, and was the engine warm?
Old Dec 8, 2012 | 11:14 AM
  #28
George Dorn
I did it again, this time with help as to be more accurate. So, with a warm engine, throttle all the way open, and an exact amount of oil in each chamber, I got this:
Dry
1 - 200
2 - 200
3 - 200
4 - 200
Wet
1 - 210
2 - 210
3 - 225
4 - 225
The pressure jumped by the same amount each time it built up in each cylinder, evenly across the board in both wet and dry. As I've said, cylinder #3 had visible sludge in it, and the spark plug was fouled like crazy. I have not done a leak down test yet.
Old Dec 8, 2012 | 04:30 PM
  #29
Moparkyle's Avatar
Moparkyle
I would say get an accurate leak down tester. I was just working on a PT cruiser this week with readings that were
1- 170
2- 150
3- 150
4- 170
Which normally wouldn't bother me, but I leak tested it anyways and found that it had a bad head gasket.
Old Dec 9, 2012 | 02:34 PM
  #30
darthroush's Avatar
darthroush
Section Moderator
I think a leakdown test is next, yes.
