Vibration, EVAP, RPM Drop
Try run the vehicle without Drive belt. Sometimes it could be an accessory pulley being out of balance.
Or maybe a bad Harmonic Balancer itself, which I've seen a few times. Pry on the Harmonic Balancer, see if the Rubber parts are worn out and falling apart.
Hey guys, I'm new to this fourm and glad to be a new member. I have recently just noticed that my 2nd gen. neon has just started to have this low rpm idle issue. it did not occur before. however, I notice that it happens when my car is at normal operating temp; then out of no where the car drops to about 500 rpm's. I thought it was an IAC, but, I tested it and it checks to be ok. although, while I was digging around by my TB I found that I had oil in my intake manifold. could this cause bad combustion and cause the rpm drop?
So, what's up with deleting all of your posts in this thread? Can't help with the "update" of the problem when you delete everything, making this thread useless to everyone now...
