turns over doesn't start.
Old Oct 7, 2012 | 11:53 AM
palegrnstars's Avatar
palegrnstars
Default turns over doesn't start.
'03 Neon SXT. Replaced engine about 3 months ago. Last 2 weeks it was having a rough time starting. Finally one morning wouldn't start at all. Will turn over though, replaced plugs and wires, jump started it and it started right up. Took it to my mechanic just to double check. Stayed 2 days and it started up every time. Got it home, the next morning same problem. Towed to garage, he played with the plugs on the computer and it started right up. Ran great for 2 days and again this morning wouldn't start, not even with a jump. I played with the cables on the computer and still had no luck. It's getting fuel. Both my mechanic and I are stumped, anyone have any ideas?
Old Oct 7, 2012 | 12:54 PM
Goromous's Avatar
Goromous
Short in the wiring harness perhaps.
Old Oct 8, 2012 | 01:29 PM
palegrnstars
The person who did the engine swap has said it may be the fuel pump not having the correct pressure. Not sure, I'm pretty convinced it has something to do with wiring our the computer. *really hoping it's not the computer*
Old Oct 9, 2012 | 10:49 AM
Goromous's Avatar
Goromous
How's the battery's wiring? As in battery to starter specifically. I had a bad cable that caused me to have a similar issue, wouldn't start even with jump.
Old Oct 9, 2012 | 11:06 AM
palegrnstars
I checked those, all good. We did try to override the battery and hooked the jumper cables directly to the battery cables and still got nothing. I'm rarely stumped when it comes to my car but this time it's got me. :-(
Old Oct 18, 2012 | 06:26 PM
arnonefrank13's Avatar
arnonefrank13
have the coil checked witha multimeter. and see if the alternator is charging the battery. also check all grounds
Old Oct 19, 2012 | 10:15 AM
palegrnstars
Got a phonecall this morning. The crank and cam sensors were junk. All that trouble because of a couple little sensors. I miss the old days of no computers and sensors.
