rear brakes locked up!?!?!?!
Old Oct 11, 2012 | 04:53 PM
liveyourlife304's Avatar
liveyourlife304
Exclamation rear brakes locked up!?!?!?!
rear brakes in my 2004 dodge neon locked up again!!!! i recently replaced rear brakes and hardware a few months ago and they locked up again!!!! any ideas on how to fix this and any ideas on what caused it to happen?
Old Oct 11, 2012 | 10:36 PM
Moparkyle's Avatar
Moparkyle
What makes you think the brakes locked up?
Old Oct 18, 2012 | 06:22 PM
arnonefrank13's Avatar
arnonefrank13
its the parking brake cable or the wheel cylinders. or the clips that hold the shoes on the backing plate.
Old Oct 18, 2012 | 07:25 PM
J.Feller's Avatar
J.Feller
Default brakes locked up
Inside the brake drums there is a lever that is actuated by the parking brake cable. if you take that lever out and wire brush the rust off and paint it (with High temperature Caliper Paint) it should stop seizing up. if all else fails, lube the inner workings of the drums with some anti-seize grease.
